1998 Mazda 626 Compression
JASONBOLINGER
Engine Mechanical problem
1998 Mazda 626 4 cyl Front Wheel Drive Automatic
The Timing belt tensioner spring failed causing the belt to jump. I replaced the timing belt and tensioner spring. I have checked three times over to make sure i was in time and that my marks lined up. The timing is correct and the car will not fire. I did a compression check in all 4 cylinders and i only build 30lbs of compression in each cylinder. WHAT IS GOING ON?
Jun 3, 2010 at 10:01 AM
  • 75,988 POSTS
Put the engine on TDC/0deg on compression stroke-look where the rotor button is pointing at is at no.1 cap tower or on no.4
Jun 4, 2010 at 2:31 AM
