1998 Mazda 626 Check engine light- oxygen sensor failure
10,700 MILES • 6 CYL • 2WD • AUTOMATIC
JINNEEBHAT
Mazda 626 10700 miles.
I got a check engine light recently. It was diagonised for a oxygen sensor failure. Replaced the sensor but got it back within 30 miles. Another sensor had failed so replaced it again. After 10 miles, the checklight is back again.
Is there something wrong with my car or I need to consult some other automobile engineer?
Feb 15, 2009 at 3:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Usually a faulty catalytic converter will throw the oxygen sensor code. I suggest having the cat. converter tested. If it is bad, it can also cause the sensors to go bad..
Thanks for using 2CarPros.com!
Feb 15, 2009 at 3:36 PM
