1998 Mazda 626 BATTERY WILL NOT HOLD CHARGE
112,000 MILES • 6 CYL • FWD • AUTOMATIC
MAZDAMAN08
The check battery light on my 1998 Mazda 626 ES came on last Thursday. Since I have a Sears Diehard battery with a replacement warranty, I took the car to Sears and had them test the battery. They recharged the battery and said it tested fine. On Saturday the car died, and I had to have it towed. My mechanic ran a diagnostic, and said the car and the alternator tested fine, and the problem is a bad battery.
They charged the battery, and I drove back to Sears. After another battery test, they again told me the battery is good, and refused to replace it. When I got back in my car, the battery light was on again. What should I do?
I am thinking about buying another battery. If the same thing happens again with a new battery, doesn't it mean there is a problem with the car?
Jul 14, 2008 at 4:12 AM
KHLOW2008
  • 41,812 POSTS
Hi mazdaman08,
Thanks for the donation.
I would suggest checking the alternator charging again.
Test the voltage at alternator and battery when vehicle is running.
Run for a longer period and with full load, ie all lightings and AC on.
If the charging voltage drops badly, it could be the pulley. There is a damper rubber ring and it could be faulty resulting in slippage of the alternator pulley.
Jul 14, 2008 at 6:51 AM
