1998 Mazda 626
1998 MAZDA 626
147,000 MILES • 6 CYL • 2WD • MANUAL
AARBEAR87
lights come on on the dashboard, the lights that come on is the abs light and the tcs light. When these lights come on the belt squeeks, but it is a brand new belt and a fairly new alternator. This has resulted in both headlights blowing out. I think there is a shortage somewhere.
Jun 6, 2008 at 9:29 PM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
You have a loose belt and it need to be tightened
ABS and TCS light on you need to check brake fluid level check brakes
and if all OK have it scanned for codes as it is a malfunction sensor
as for the headlight check the fuses and check the bulbs and replace
Jun 6, 2008 at 9:45 PM
