1997 Mazda 626 water pump
1997 MAZDA 626
190,000 MILES • 4 CYL • FWD • AUTOMATIC
SHOWOWNER
Is it possible for the water pump on this vehicle to sometimes leak. It at times appears to look like drips coming from the pulley area!On a domestic vehicle the area would indicate water pump and it would continue to leak daily. On this mazda it might be leaking 1 day you top the radiator off and it might not leak again in that area for 4 or 5 days and the water level is full. When it is leaking though you always have to add water.Just kind of curious can they sometimes do and sometimes don't
Jun 21, 2010 at 1:31 PM
SATURNTECH9
  • 30,869 POSTS
Anything is possible try pressure testing the cooling system and see if it's leaking.If you can't find it that way get some coolant dye and add that and follow the dye to the leak.
Jun 21, 2010 at 5:51 PM
