1995 Mazda 626 Water Pump Replacement Fix
ADU
  • 15 POSTS
1995 Mazda-626 V6 135,000miles.
What are the steps to replacing the water pump?
What tools will I need to do this?
Thanks,
Adu
Dec 20, 2006 at 3:15 AM
MATHIASO
  • 1,209 POSTS
The exact design of the water pump and it location vary slightly from engine to engine.
in some engines the water pump is driven by the engine's drive belt, while in others the pump is driven by the engine's timing belt..Since each vehicle is slightly different, you usually need to refer to the vehicle's service manual to determine the exact procedures needed to remove and replace the water pump; but I can help you :
1- drain the coolant fromthe system
2-if the pumhas radiator hose attached directly to it, loosen the hoseand remove it from the pump and / or any other hose attache to the water pump.
3- if the radiator fan is attached to the water pump loosen the retaining bolts with an appropriate wrench and remove the fan
4 -Loosen the tension on the belt and remove the belt from the engine.
5using an appropriate wrench remove the bolts that hold the pump housing to the engine, in many cases the lengh of the bolts varies pay attention to them.
5-After all bolts have been removed, remove the water pump from the engine.
6-When the old pum is off the negine, clean any leftover gasket material from the area
- compare the new water pump with the one you just remove from the engine, they must be same
7- reverse the disassembly steps to complete the job.
Dec 20, 2006 at 3:53 AM
COSMO
  • 347 POSTS
There are alot of tools you require to do a water pump on a V6 626 motor. 10, 12, 14, 19, 21 mm wrechs and sockets. And impact (1/2) gun.
Lots of 1/4 3/8 extensions.
The whole job takes about 4-5 hours in my Mazda shop.
Its really not for the do-it yourself kinda person.
You will alos need to remove the timing belt to get to the water pump (the pump is behind the belt).
Also you need to know what to look for in the way of a loose timing belt tensioner (they are famous for being loose at such and old age).
Good luck if you try it yourself, but I would leave this one to the professionals.
Cosmo...Mazda Tech
Dec 20, 2006 at 3:57 AM
Suggested Repair
Drain the coolant, remove any hoses and fan attached to the pump, release belt tension, and remove the water pump bolts while noting their lengths. On this V6 the pump is behind the timing belt, so the timing belt must be removed and the tensioner checked for looseness. Clean the gasket surface, confirm the new pump matches the old one, and reassemble in reverse. Typical shop time is 4-5 hours; tools include 10, 12, 14, 19, and 21 mm wrenches and sockets, extensions, and a 1/2-inch impact gun. A professional is recommended if you are not experienced with timing-belt work.
Conversation Summary
The owner of a 1995 Mazda 626 V6 with 135,000 miles asked for water pump replacement steps and required tools. One reply gave general steps: drain coolant, remove attached hoses and fan, release the belt, unbolt and remove the pump, clean gasket material, compare the new pump, and reassemble. A Mazda technician added that the V6 pump is behind the timing belt, so the belt must come off and the tensioner should be checked for looseness. The job needs metric wrenches and sockets, extensions, and an impact gun, takes about 4-5 hours, and is better left to a professional.
