1997 Mazda 626 transmission speed sensor replacement
MICAR
Engine Performance problem
1997 Mazda 626 4 cyl Front Wheel Drive Automatic
The code says that the speed sensor is bad. How to replace.
May 20, 2010 at 11:01 AM
BLUELIGHTNIN6
  • 16,542 POSTS
vehicle speed sensor, input speed sensor or turbine shaft speed sensor?
May 20, 2010 at 2:36 PM
MICAR
Thanks for replying so quickly. I Looked up what the code meant and it said Input/turbine speed sensor a circuit malfunction.. Any ideas? Thanks. Micar
May 20, 2010 at 7:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
most likely indicates a faulty input speed sensor, which is located on the left rear of the engine compartment, in the transmission
May 21, 2010 at 7:28 AM
