1997 Mazda 626 Reset engine light
135,000 MILES • 6 CYL • 2WD • MANUAL
WUBE
I disconnect the intake air sensor to the mass airflow sensor to clean the throttle. After putting the tubes back on the throttle, I forgot to reconnect the intake air sensor and started the car. The car shook and the engine was immediately turned off. After a quick look I reconnect the electrical but the engine light came on.
The car runs fine now and it no longer shakes when idle (why I clean the throttle at the first place).
I've learned that I can disconnect the negative battery and hold the break for 30 second to get rid of engine light. Is that the best way to turn off the engine light? Does this reset any other computer programs? I did this once long ago and I needed someone to jump start my car and not sure if I should use this technique again. Thanks.
Apr 3, 2010 at 4:10 PM
LEGITIMATE007
  • 5,121 POSTS
the best way is to just take it to autozone or your local parts place and have it erased, that way you dont risk loosing settings etc.
Apr 3, 2010 at 4:25 PM
