1997 Mazda 626 Not Starting
172,000 MILES • 4 CYL • FWD • AUTOMATIC
JOE HALE
The 1997 Mazda 626 will sometimes not turn over and /or start when I turn the key . The lights and radio work at full strength but sometimes I have to turn the key off and on 3 or 4 times and then it starts. Put in a new battery and cleaned the terminals well with no success. There is no set time or weather condition specific too this problem. Trans neutral switch ? Starter ? I mean it does nothing one moment and starts and runs fine the next.
Oct 3, 2009 at 3:40 AM
  • 75,988 POSTS
Try remote starting the starter if it cranks the engine over check and test the starter relay, park/neutral position switch and ignition switch
Oct 3, 2009 at 3:56 AM
