1997 Mazda 626 Leaking yellowish fluid on the passenger side
FRESNOISTHECITY
  • 1997 MAZDA 626
  • 4 CYL
  • FWD
  • MANUAL
  • 202,000 MILES
I've been leaking yellowish fluid under the passenger side from the back door to about halfway up the front passenger side. The passenger-side underbody looks saturated with this yellowish fluid that has been dripping since yesterday, since I had the battery changed at Wal Mart. Also this morning I was overheating when it was 30 degrees outside I only had about 6 miles to travel but I still had to pull over and let her cool off before finishing my drive. Any suggestions? Should I even be driving her to work?
Monday, December 10th, 2007 AT 4:45 PM
MERLIN2021
  • 17,250 POSTS
If the car has rear heat, get under there and check for leaking antifreeze lines. Also check the radiator level.
Monday, December 10th, 2007 AT 4:50 PM
