1997 MAZDA 626 HEAVY VIBRATION
TROYMAJESTY
I HAD EVERYTHING THING YOU CAN IMAGINED REPLACED ON THIS CAR, HEADS, TRANNY, EXHAUST, MOUNTS, ALL SENSORS , ETC. THE PROBLEM IM HAVING IS THAT WHEN IN PARK THE CAR VIBRATES HEAVY, BUT WHEN I ACCELERATE ITS FINE UNTIL I COME TO A RED LIGHT OR A COMPLETE STOP THEN IT STARTS TO VIBRATE VERY HEAVY, NOW I TOOK IT TO THE SHOP TO GET AN EXPLANATION THEY TOLD ME IT COULD BE THE TORQUE CONVERTER, THEN I TOOK IT TO ANOTHER SHOP THEY TOLD ME ALSO IT COULD BE THE TORQUE CONVERTER, I TOOK IT BACK TO THE TRANNY SHOP THEY REBUILT THE TORQUE CONVERTER AND REPLACED THE RCI BUT IM STILL HAVING THIS HEAVY VIBRATION. CAN ANYONE SHINE SOME LIGHT ON THIS MATTER IT WOULD BE GREATLY APPRECIATED.
1997 MAZDA 626 LX
2.0 4CYL.
132,000 MILES
Jan 11, 2006 at 8:42 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have actual idle speed, engine running quality and mount condition and installation assessed before further transmission work. Use the correct specifications instead of raising idle to mask the complaint.
Guidance references and applicability
Source: This question and its visible discussion, including any clearly labeled editorial corrections. Owner reports are distinguished from other participants' experiences. Follow-up guidance is not a confirmed diagnosis.
Read the replies · Discussion summary and reported outcome
10FOTUCK
  • 28 POSTS
2CarPros editorial correction - October 12, 2026
The earlier suggestion to increase idle speed in Drive or use Neutral as a repair has been withdrawn. Have the vibration diagnosed, including actual idle speed, engine running quality and the condition and installation of the mounts, using the correct vehicle specifications. Do not adjust idle controls to mask an unidentified fault. Another owner's similar symptom does not establish the cause, and no successful repair was reported for the original Mazda.
Jan 15, 2006 at 9:13 AM
MADDISON
  • 28 POSTS
Does the car have a harmonic balancer?? I know some chev v6s were bad for that.
Feb 20, 2006 at 9:17 AM
Discussion summary
A 1997 Mazda 626 2.0 vibrated heavily at idle and stops despite extensive reported repairs, including work on mounts, the transmission and torque converter. The vibration reportedly eased with acceleration.
Reported outcome: No successful repair was reported.
The parts list did not establish which tests had been performed or prove a converter fault. Advice to increase idle in Drive or use Neutral as a repair was withdrawn.
Read the original discussion
