1997 Mazda 626 Engine Overheating
12,000 MILES • 6 CYL • FWD • AUTOMATIC
HN2000
Hi there, this is regarding my engine overheating. When I drive my car into the city it tends to overheat but I noticed that when I drove it on the highway it went back to normal temperature. Also putting the heat on the car tends to help a bit. I flushed and refilled my anticoolant, changed my timing belt, and changed the engine oil all recently. Any suggestions you have for me so the engine would stop overheating?
Oct 25, 2009 at 4:06 PM
  • 75,988 POSTS
Are the cooling fans coming on? radiator not clogged and water pump doing its job,could be air in the system try bleeding it
Oct 25, 2009 at 4:48 PM
