1997 Mazda 626
MSCASTRO626
  • 1997 MAZDA 626
  • 4 CYL
  • 179,098 MILES
When I start my car it doesnt stay running unless I put my foot on the gas? I was told it could be the fuel pump if so roughly how time consuming would it be to fix?
Tuesday, February 24th, 2009 AT 11:05 AM
ZACKMAN
  • 4,202 POSTS
Not your fuel pump. If it is your pump, it won't even run. You need to perform a fuel pressure test to make sure the pressure regulator is working.
You said you have to maintain the gas pedal. What rpm is that? If it is higher than 800 rpm, you have idle problem. Check for vacuum leaks, or possibly your idle air control valve. It may also be the throttle position sensor or the mass air flow sensor.
Tuesday, February 24th, 2009 AT 10:40 PM
