1995 Mazda 626
CWMOND
Engine Performance problem
1995 Mazda 626 6 cyl Two Wheel Drive Manual
was wonding if anyone has had this happen ? Has 155k miles runs fine until seems like it gets hot then sometime starts to act like not getting gas . had fuel pump checked was fine . Was wondering if this car has vaper lock
Jun 5, 2010 at 4:23 PM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 5, 2010 at 4:38 PM
