1996 Mazda 626 over heating
108,000 MILES • 6 CYL • FWD • AUTOMATIC
COTTONBOY
my 626 over heats constantly. i checked the thermastat and it is goog. it is full of 50/50coolant , is there maybe something clogged up in the system and how would i check for it?
Mar 1, 2010 at 11:48 PM
LEGITIMATE007
  • 5,121 POSTS
verify that the fans are coming on, you may have a bad motor or fan relay, best thing to do is, hardwire the fan to the battery to see if it comes on, if it does, I suspect the relay or the engine coolant temp sensor,which tells the ecm that the coolant is hot enough to turn the fan on and bring the temp down
Mar 3, 2010 at 2:22 PM
