1996 mazda 626 headlamp removal
1996 MAZDA 626
JON C. MILLER
I was wondering if you can tell me or show me with a diagram how to remove the headlamps from my 1996 mazda 626. I would like to clean them too so if you can maybe give me some pointers on that as well I would really appreciate it. Thanks!!
Sep 5, 2007 at 11:40 AM
FAIRRACING31
  • 150 POSTS
1. Unplug the electrical connectors, and remove the halogen bulb.
2. Remove the grill on models so equipped.
3. On some Mazda models, the front combination (park and turn signal) light is incorporated into the headlight housing, while on other models the headlight housing is separate unit. On models with separate combination lights, remove the combination light for access to the outer headlight housing bolts. On models with a radiator grill, remove the grill for access to the inner headlight housing bolts.
Oct 21, 2007 at 8:15 AM
