1996 Mazda 626 Engine hesitating
142,000 MILES • 4 CYL • 2WD • AUTOMATIC
POLISHPRINCE166
Engine hesitates when going uphill. I have replaced the 02 sensor, spark plugs and wires, distributor cap and rotor.
My next step is to replace the fuel filter. Am I on the right track?
Thanks
Rob
Jun 15, 2008 at 2:12 PM
  • 75,988 POSTS
Do you have a check engine light and when the last time you disconnected the battery?
Check the fuel pressure/throttle position sensor/MAF/MAP sensors.
Jun 15, 2008 at 3:26 PM
POLISHPRINCE166
Yes, the engine light is on. I disconnected the battery then reconnected it yesterday. The engine went off, but then came back on as I drove the car yesterday.
I will do the checks that you suggest, especially the throttle position sensor.
Is it even worth replacing the fuel filter, at the same time, or is that a waste of time/money?
Thanks
Jun 16, 2008 at 2:51 AM
