1996 Mazda 626 cv joints
DEN1197
Other Category problem
1996 Mazda 626 Engine Size unknown Two Wheel Drive Manual 101233 miles
Need to know how to remove old cv joint from bracket on axle, or a diagram.
Feb 10, 2008 at 1:47 AM
MERLIN2021
  • 17,250 POSTS
You'll need a socket large enough to remove the axle nut, and a tool to break the ball joint free. Then just pull the strut rotor and all outward until the cv-joint clears the knuckle, I would change the whole shaft, Reanufactured axles are pretty cheap, and it's quicker and easier than messing with seperating the old joint! Use a bucket under the inner joint to catch any tranny fluid that might leak out! If you have trouble with the inboard joint, use to large flat blade screwdrivers, or prybars and pop it out of the differential...
Feb 10, 2008 at 2:07 AM
