1996 Mazda 626 clutch master cylinder
1996 MAZDA 626
177,000 MILES • 4 CYL • 2WD • MANUAL
BHUERTA
where is it located and isit the sameasthe brakemaster cylinder? also i wastold youcould just add brake fluid somewhere to get my pedal from staying stuck down is that true?
May 23, 2009 at 6:24 AM
DOCFIXIT
  • 18,828 POSTS
It is below the brake master fluid in brake master flows to clutch master by a hose. Add fluid to brake.
Most likely you have bad slave cyl. on trans. or pressure plate failure
May 23, 2009 at 6:50 AM
