1995 Mazda 626 will not start
267,227 MILES • 4 CYL • FWD • MANUAL
My car will not start all light come on but when I push in clutch and turn key it will not start what is the problem?
Jun 30, 2009 at 2:31 PM
  • 75,988 POSTS
If its cranking over and refuses to start-Do below to determine if its fuel or spark problem
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Jun 30, 2009 at 4:14 PM
