i am unsure if the timing is off or maybe a vacuum line is off? it bogs when you give it fuel. it' not responding correctly.
Apr 20, 2008 at 10:06 AM
✓Experienced Mechanic
Check all the tune items, plugs, leads, filters. to check timing for the FS engine which i feel is yours loop the GND & TEN connectors in the diagnostic link connector and check timing at idle hot 12 Deg BTDC
