1995 Mazda 626 new oil pump
130,000 MILES • 4 CYL • FWD • AUTOMATIC
KAPER
I recently replaced my valve cover gasket. I have an oil leak and thought I might as well fix it while I was working on the car. I took off the valve cover and there was black build-up under the cover. I took to the task of scraping it off the best I could, taking care not to let the guck fall into the engine. I thought I had done a good job. But, now when I drive the car, the oil light comes on and it starts ticking real bad. My question is could I have possibly plugged up my oil pump with some of the guck that inevitably did fall down. I have added build-up remover and changed my oil twice, since the gasket replacement. Is that possibly my problem and how hard of a repair is that for me to do myself.
Nov 4, 2008 at 8:01 AM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge-could be a weak oil pump/engine bearings/oil galleries/sludge up pick up strainer
Nov 4, 2008 at 9:27 AM
