1995 Mazda 626 Fuel pump
Engine Performance problem
1995 Mazda 626 4 cyl Two Wheel Drive Automatic 112.00 miles
When key ignition ON no pressure on gauge and no sound fuel pump throgh filler neck , pressure only when cranking increased . Before was changed fuel pump , and pressure regulator and fuel filter .
And in summer fuel mesure showed gasoline in the thank , but after couple minutes of work showed less gasoline ? what the problem ? Thank You!
Nov 23, 2009 at 6:35 PM
  • 75,988 POSTS
Check and test the fuel pump relay and PCM power relay
Nov 23, 2009 at 8:10 PM
