1995 Mazda 626 Changing front brakes
114,000 MILES • 4 CYL • FWD • AUTOMATIC
BERNIE GONZALEZ
While attempting to remove front brake caliper, I can locate only one bolt which has the allen-wrench-type head, with a rubber housing around it. Shouldn't there be two?
I did locate 2 other larger bolts with conventional heads. Do all three need removal in order to change the pads?
Jun 23, 2008 at 5:26 AM
DOCFIXIT
  • 18,828 POSTS
Take the lower bolt out swing caliper up take out the pads, push piston back instal new.
Good luck
Jun 23, 2008 at 5:46 AM
