While attempting to remove front brake caliper, I can locate only one bolt which has the allen-wrench-type head, with a rubber housing around it. Shouldn't there be two?
I did locate 2 other larger bolts with conventional heads. Do all three need removal in order to change the pads?
Jun 23, 2008 at 5:26 AM
