1995 Mazda 626 Won't Accelerate
JOHN ELLIFF
car left in the yard for 3 yrs son bought it and drove it part way home it died, i got it home and started it , it ran smooth, checked the water it was out added water to radiator and found the head gasket was blown, replaced head gasket and water pump, first time we started the car the timing was off with the cams and all remidied this and it and drove the car up the street and back ( 1/2) mile or so,,,, but now the car starts , but will not acclerate at all ,it sounds like its bogging down and shudders, still it will return to idle and run ok , the codes from the check engine light said " mas air flow sensor" and throttle position sensor", which one is the culprit, or is there something else that might be the problem??? really could use some help on this one . "dad is supposed to fix everything you know "
May 11, 2007 at 6:02 AM
  • 75,988 POSTS
[quote:d167446baf="john Elliff"]car left in the yard for 3 yrs son bought it and drove it part way home it died, i got it home and started it , it ran smooth, checked the water it was out added water to radiator and found the head gasket was blown, replaced head gasket and water pump, first time we started the car the timing was off with the cams and all remidied this and it and drove the car up the street and back ( 1/2) mile or so,,,, but now the car starts , but will not acclerate at all ,it sounds like its bogging down and shudders, still it will return to idle and run ok , the codes from the check engine light said " mas air flow sensor" and throttle position sensor", which one is the culprit, or is there something else that might be the problem??? really could use some help on this one . "dad is supposed to fix everything you know "[/quote:d167446baf]
Clean out the MAF and readjust the TPS. also check the fuel pressure. Double check for vacuum leak and inspect the EGR and PCV valve.
Hope this help Good Luck
May 15, 2007 at 10:29 AM
Suggested Repair
Clean the MAF sensor and readjust the TPS. Also check fuel pressure, look for vacuum leaks, and inspect the EGR and PCV valves.
Conversation Summary
A 1995 Mazda 626 that sat for three years had a blown head gasket and water pump replaced, and cam timing was corrected after it was initially off. It now starts and idles but bogs, shudders, and will not accelerate. Check-engine codes point to the mass airflow and throttle position sensors. The expert advised cleaning the MAF, readjusting the TPS, checking fuel pressure and vacuum leaks, and inspecting the EGR and PCV valves.
