1995 Mazda 626
18,400 MILES • 4 CYL • 2WD • AUTOMATIC
NMFL83
I have a mazda 626, 4 cyl that will not turn over at all. I have a battery tester and the battery tested out fine (lights on, horn honks, radio comes on). It doesn't make a single noise at all when u turn the key.
Aug 3, 2009 at 8:15 AM
  • 31,937 POSTS
Hi there,
You will need to get the voltage at the starter solinoid tested with the key on crank, if nothing, have the transmission idolater check and the ignition lock checked, if power at the starter, the starter will be faulty, start here.
mark (mhpautos)
Aug 3, 2009 at 10:12 AM
