1995 Mazda 626
NMFL83
  • 1995 MAZDA 626
  • 4 CYL
  • 18,400 MILES
I have a mazda 626, 4 cyl that will not turn over at all. I have a battery tester and the battery tested out fine (lights on, horn honks, radio comes on). It doesn't make a single noise at all when u turn the key.
Monday, August 3rd, 2009 AT 3:15 PM
  • 31,937 POSTS
Hi there,
You will need to get the voltage at the starter solinoid tested with the key on crank, if nothing, have the transmission idolater check and the ignition lock checked, if power at the starter, the starter will be faulty, start here.
Mark (mhpautos)
Monday, August 3rd, 2009 AT 5:12 PM
