1994 Mazda 626 clutch or transmission
195,000 MILES • 4 CYL • FWD • MANUAL
JOEHH24
When i start the car up in neutral with the clutch engaged i get a rattling noise. Is this a problem with my pilot bearing or pressure plate or is it a bad syncronizer or something else with the transmission?
Feb 19, 2008 at 11:06 AM
2CARPRO JACK
  • 11,533 POSTS
Usually clutch issue will make noise with while idling or when the clutch isnt engaged. Yours sounds like it may be a bearing problem in the trans, input shaft perhaps
Feb 19, 2008 at 11:19 PM
