1993 Mazda 626 not charging properly
ROWSIE
Electrical problem
1993 Mazda 626 6 cyl Front Wheel Drive Automatic
my daughter's alternative recently failed. went to 3 mechanics to get fixed. finally thought it was repaired correctly. the last one "chased" the wires and secured a loose connection, and replaced the alternator. seemed to be working better than ever for about 2 weeks. last fri daughter drained the battery leaving the lights on. she jump started it, and now the battery seemingly wont charge fully. after running the car for what seemed a sufficient time, 30-40 min, the battery is weak and barely has enough energy to turn over the next morning. this has happened 2-3 times since the battery was drained. is the battery failing or is there still a problem with the alternator/electrical system?
Jul 5, 2010 at 4:06 AM
  • 75,988 POSTS
To find out get both the alternator and battery load tested if both okay-there's a short circuit draining the battery overnite
https://images.2carpros.com/forum/automotive_pictures/12900_parastic_draw_1_228.jpg
Jul 5, 2010 at 5:18 AM
