1993 Mazda 626 No speedometer or cruise
1993 MAZDA 626
131,000 MILES • 4 CYL • FWD • MANUAL
MARRS911
I have lost my speedometer/odometer and cruise control. I replaced my VSS and tested it. It has fluctuating voltage when you spin the wheel. All other guages work fine. It may be a coincidnece but I installed a new stereo and new battery prior to the guages going out. If the guage itself is bad would this cause the cruise not to function.
Thanks
Jul 3, 2009 at 5:03 AM
BUDDYCRAIGG
  • 2,262 POSTS
yep, the speedo has to work for the cruise to work.
there are 3 wires for the speedo.
pin 1B has a red-black wire that goes to the VSS
pin 1F has a orange-black (or possibly gray-blue) wire that goes to the VSS
pin 1H has a green-red wire that goes to the cruise control, the computer, and the traction control.
since you do not have a speedo, check the first two wires. you may have damaged them, or pulled on them and something got unplugged when you put in your radio.
good luck.
Jul 3, 2009 at 1:21 PM
