1993 Mazda 626 Dies While Cruising
EXSQUID
1993 Mazda 626 w/2.0l 4 cyl. & manuel transmission. 170000 miles. Car dies while driving but will restart within
minutes. Had the fuel pressure checked ( it was low, around 63 psi ) so I replaced the fuel pump and strainer. Car still dies while driving. This has not happened at speeds below 25 mph. There are no idiot lights lit until of course it dies. Plenty of power otherwise. Any ideas?
Jul 5, 2007 at 5:46 AM
DANCARLSON
  • 50 POSTS
Is it just that the engine dies or do you lose all electrical power?
Jul 6, 2007 at 12:15 AM
EXSQUID
Just the engine dies. I have noticed that it will die at all speeds and occasionally backfire while restarting the engine. I still have electrical power, lights radio etc. and if I turn the key off then to on/run for a few seconds before trying to restart it seems to restart quicker. Also, there seems to be no set number of times it will die. Yesterday it died six or seven times going to work and then not at all coming home, a distance of approximately 45 miles. Wierd huh?
Jul 8, 2007 at 3:57 AM
DANCARLSON
  • 50 POSTS
If just your engine dies then it must be a problem with the distributor or coil.
Jul 11, 2007 at 12:04 AM
EXSQUID
Thanks, I'll check them both out and let you know.
Jul 11, 2007 at 6:57 AM
MALCOLMGREY
sounds like it could be the CMP overheating
Jul 12, 2007 at 10:47 AM
  • 75,988 POSTS
[quote:bde49dac51="Exsquid"]1993 Mazda 626 w/2.0l 4 cyl. & manuel transmission. 170000 miles. Car dies while driving but will restart within
minutes. Had the fuel pressure checked ( it was low, around 63 psi ) so I replaced the fuel pump and strainer. Car still dies while driving. This has not happened at speeds below 25 mph. There are no idiot lights lit until of course it dies. Plenty of power otherwise. Any ideas?[/quote:bde49dac51]
Could also be the ignition control module
Jul 13, 2007 at 8:24 AM
Suggested Repair
Because the engine dies while electrical power remains and a new fuel pump did not stop the stalling, inspect the distributor, ignition coil, ignition control module, and camshaft position sensor for an intermittent ignition fault.
Conversation Summary
A 1993 Mazda 626 with a 2.0L engine and about 170,000 miles dies while driving, then restarts within minutes. Fuel pressure was low, so the fuel pump and strainer were replaced, but the stalling continued at various speeds. Electrical power stays on, and the engine sometimes backfires during restart. Replies suggest checking the distributor, coil, camshaft position sensor, and ignition control module.
