1993 Mazda 626 low engine torque or power over hills
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHRISTAIN
I can drive my car on a flat service but the engine just rev's when I try to climb up any little or larger uphill grade.
If it were a transmission problem, would I be able to move at all?
Oct 11, 2008 at 3:55 AM
DOCFIXIT
  • 18,828 POSTS
Do the RPMS go up excessively with no corresponding speed increase. If so sounnds like trans is slipping.
Oct 11, 2008 at 4:06 AM
CHRISTAIN
Yes. That's correct, the RPM increases but with no increase in speed. Does a slipping transmission usually mean its time for a new or rebuilt transmission?
If so, I can't see that the car would be worth it.
Oct 11, 2008 at 6:01 AM
DOCFIXIT
  • 18,828 POSTS
You could try fluid and filter change when fluid gets old it looses adhesion to clutches. If fluid comes out dark and has a earthy burnt smell that indicates clutch pack damage and rebuild maybe necessary.
Oct 11, 2008 at 6:08 AM
CHRISTAIN
Can anyone tell me where the filter is located in the automatic transmission?
Thank you
Oct 11, 2008 at 10:16 AM
DOCFIXIT
  • 18,828 POSTS
inside the transmission when pan is removed filter is there
Oct 11, 2008 at 12:03 PM
CHRISTAIN
Thank you
Oct 12, 2008 at 1:44 AM
