1993 Mazda 626 engine cranks but won't start
189,000 MILES • 4 CYL • 2WD • AUTOMATIC
SHERRIJO
my car was running rough (sputtering) we changed the fuel filter and took it for a test drive. When we got back from the test drive it died. The engine cranks but won't start now.
this is the second e-mail i sent the first one i gave you the wrong year of my car.
please help me.
Jan 28, 2008 at 8:28 AM
BLACKOP555
  • 10,386 POSTS
Will it fire up with starting fluid sprayed in the throttle body then die when it is used up? if so its fuel related. if not its probably spark and you shoudl check for bright blue sparks at each plug.
post back.
Jan 28, 2008 at 8:46 AM
CHRIS1963
I had the same problem and replaced the the entire dist. and it fired up and is still running.
Jun 11, 2008 at 6:06 AM
