1993 Mazda 626 Alternator belt
1993 MAZDA 626
MOMS626
Engine Mechanical problem
1993 Mazda 626 4 cyl Automatic
My alternator belt broke today. I need instructions on how to replace it.
Jul 5, 2008 at 2:04 PM
KHLOW2008
  • 41,814 POSTS
Hi Moms626,
Straight forward job.
Alternator has and adjustiing bolt, release it, do not take it out. Push alternator towards engine to enable belt to have clearance to slip in.
Use a bar to pry alternator outwards to tighten the tension, pull bar hard and release, then hold bar slightly to maintain tension and retighten adjusting bolt. You are done.
NOTE : If power steering and AC belts are in the way, you need to take them out first, same procedure.
Jul 9, 2008 at 5:38 AM
