1992 handa accord car shake at idle
JUNMAX
the car starts and runs fine, has a lot of power. the only one problem is the car shake at idle. I mean the you can fell the shake inside the car from steering wheel to engine.
May 21, 2010 at 7:36 AM
  • 75,988 POSTS
Check the idle air control valve, EGR valve and test the throttle position sensor, also look for vacuum leaks
May 21, 2010 at 10:05 AM
