1990 Mazda 626 2.2L Not getting fuel to the engine!
MYCAR
I've already spent over 200 dollars on a fuel pump that I just found out I don't need....the old one is working fine, but I am still not getting gas to the engine and cannot get the car to start....Does anyone know where the relay switch is or what else could possibly be wrong? Thanks for anyone that can help.....I'm going to lose my job if I can't get this fixed soon.
Thanks,
Trish
Jan 7, 2006 at 4:46 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Document which ground connection was repaired. If the fault returns, have the relevant circuit checked under load before replacing another pump or control component.
Guidance references and applicability
Source: This question and its visible discussion. Owner reports are distinguished from other participants' experiences. Follow-up guidance is not a confirmed diagnosis. Fluke: Diagnosing voltage drops https://www.fluke.com/en/learn/blog/automotive/electrical-automotive-troubleshooting General support for loaded circuit testing; use the actual vehicle wiring and specifications.
Read the replies · Discussion summary and reported outcome
SCORPIO612
  • 5 POSTS
I am not an expert but had similar problem with my maxima. First it was the fuel injection system. Had to replace a part.
And 2nd time it was due to the Distributor cap. Distrubutor cap was cracked . Car was cranking but no spark was generating. Hopefully it helps
Jan 7, 2006 at 7:35 AM
PALOMA PAUL
  • 14 POSTS
Why do you say it's not getting fuel? Take the fuel filter to engine hose off, have a friend crank the engine, if you see fuel coming out then its probably the pressure regulator has taken a dive. If that's the case try back flushing it with Berrymans carb cleaner. If it still doesn't start try replacing the regulator. But its an expensive part $100+. Post your results.
Jan 7, 2006 at 2:36 PM
MYCAR
Thanks for the help...everyone....I know this sounds wierd...but its all fixed now...I guess it wasn't grounded properly! Thanks for the info!
Thanks,
Trish
Jan 8, 2006 at 8:43 AM
Discussion summary
The owner of a 1990 Mazda 626 2.2 reported a no-start believed to involve missing fuel delivery after an apparently unnecessary fuel-pump replacement. The final update attributed the problem to an improper ground.
Reported outcome: The owner reported that the problem was fixed after the grounding issue was addressed.
The exact ground and test results were not supplied. The reply suggesting cranking with an open fuel hose is not a recommended test.
Read the original discussion
