HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mazda
626
Engine
Starter
Replace/Remove
SPONSORED LINKS
1989 Mazda 626 Starter Location!
SAIRY
MEMBER
1989 MAZDA 626
4 CYL
FWD
AUTOMATIC
129,000 MILES
HELP!
Where is the starter located on my 1989 4cyl mazda 626?
Thanks!
Tuesday, May 13th, 2008 AT 8:05 PM
BLACKOP555
MECHANIC
It is located where the engine and transmision meet, its on the bellhousing.
SPONSORED LINKS
Tuesday, May 13th, 2008 AT 9:16 PM
SAIRY
MEMBER
Thanks for the help!
Tuesday, May 13th, 2008 AT 9:17 PM
BLACKOP555
MECHANIC
Good luck finding it.
Wednesday, May 14th, 2008 AT 4:09 PM
Please
login
or
register
to post a reply.
Related Starter Replace/Remove Content
Starter Removal
How Do You Remove & Install A Starter On A 2000 Mazda 626 4cyl 16 Valve Dohc?
Asked by
DevaJones
1 ANSWER
2000
MAZDA 626
VIDEO
Starter Replacement
Instructional repair video
GUIDE
Starter Motor Replacement
A starter motor is a high torque motor that utilizes a small pinion gear to contact the flywheel and a starter solenoid to initiate the electrical connection when the...
2000 Mazda 626 Starter
How Do You Remove And Replace The Starter
Asked by
big922
1 ANSWER
2000
MAZDA 626
2001 Mazda 626 Starter
Engine Performance Problem 2001 Mazda 626 4 Cyl Two Wheel Drive Automatic What Is The Difficulty Rating On Replacing The Starter, And...
Asked by
GOLEM.31
1 ANSWER
2001
MAZDA 626
1994 Mazda 626
How To Replace A Starter?
Asked by
etanner825
1 ANSWER
1994
MAZDA 626
Car
Having Problems Starting The Car Replace The Starter Had The Alternator Check And Battery It Was All Good. If I Keep Turning The Key It Will...
Asked by
albertguice77
1 ANSWER
1998
MAZDA 626
VIEW MORE
SPONSORED LINKS
Starter Replacement
Starter Replacement
Online car repair manuals
