1989 Mazda 626 locks
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
PHANH08
I have a question about my car. On the driver side, the lock will not pull up & on the passenger side, the lock will not open.
Jul 8, 2008 at 11:18 AM
KHLOW2008
  • 41,812 POSTS
Hi Phanh08,
If the lock cannot be pulled up, something is jamming it up, you need to remove the door panel to find out.
Does using the key works on the locks on both sides?
Jul 9, 2008 at 5:06 AM
PHANH08
No, the key does not work either. I can fit the key in & twist it in the hole but the lock does not pop. It does not even jiggle. I was reading other advices for people w/lock problems & there was one advice about using a slim jim. I will find someone w/a slim jim (as I am cheap & refuse to get overcharged by a locksmith). Wish me luck. Thank you for all your help =)
Jul 9, 2008 at 5:30 AM
KHLOW2008
  • 41,812 POSTS
Hi Phanh08,
Good luck.
If you got a long metal ruler, you can try pushing it around into the lock area from the door glass and the lock might pop up ;)
Jul 9, 2008 at 5:33 AM
