1985 Mazda 626 water spraying out of top of rad
MTLOVE1
Engine Cooling problem
1985 Mazda 626 4 cyl Four Wheel Drive Manual
i am guessing at the year of the car.it is an oval track stock car we just got for free.it had a rotten hose from the block to the heater core so i removed both heater core hoses and just by passed the heater core totally.so when i start the car now the coolant is super pressurized and sprays out from the rad cap.if you take the cap off it is like a fountain shooting out.do i have a blown head gasket and the exhaust is getting into the cooling system?by passing the heater core shouldn't do this.any ideas.thanks
Nov 8, 2009 at 10:22 AM
BMRFIXIT
  • 19,053 POSTS
If the coolant spray out the radiator cap as engine start almost for sure suspect at least a blown headgasket
Nov 8, 2009 at 11:36 AM
MTLOVE1
thanks for the reply.so if on start up (cold engine) the coolant just starts gushing out of the rad...you are saying that is a head gasket?so the exhaust or compression must be forcing the water out.could it be ANY other thing besides a totally blocked radiator?
Nov 8, 2009 at 2:28 PM
BMRFIXIT
  • 19,053 POSTS
Part stores should have a headgasket test kit
its a fluid tube that change color if exhaust gases present in the coolant system
totally blocked radiator may be the cause of the head gasket failure but I dont think its the reason that forcing the fluid out
pull spark plugs and check if wet
Nov 8, 2009 at 9:58 PM
