2005 Mazda 6
BETTYHH
Steering problem
2005 Mazda 6 6 cyl Automatic 130,00 miles
my steering wheel gets really hard when i'am trying to turn either way....but the fluid level is fine...and if i put it on park and hit the gas a lil the wheel loosens up.Do i need to change the p/s pump???
Aug 18, 2010 at 11:20 AM
  • 31,937 POSTS
HI there, check that the drive belt for the pump is not slipping, check this first.
mark (mhpautos)
Aug 18, 2010 at 9:48 PM
BETTYHH
hi....i checked the belt and its not slipping...so is there anything else i can check????thanks for the help
Aug 19, 2010 at 9:50 AM
  • 31,937 POSTS
Hi there, if the belt is ok and the oil is ok, i feel it will be a faulty pump.
Mark (mhpautos)
Aug 19, 2010 at 2:48 PM
BETTYHH
hi...i have one more question.My friend is a mechanic and he said my car takes transmission oil instead of power steering fluid because is a mazda and its a newer model.And the problem is that my brother drained it and filled it with power steering fluid.Does this sound ok or maybe he doesn't know what he's talking about???
thanks for your help!!!!
Aug 20, 2010 at 6:27 AM
  • 31,937 POSTS
Hi there,
The power steering can use Dextron 111 transmission oil with out a problem.
Mark (mhpautos)
Aug 20, 2010 at 12:13 PM
