what happens if you red line the car? It seems to be running fine and normal, but there is an odor
Dec 5, 2008 at 1:23 PM
✓Experienced Mechanic
Hi there, Red lining or max engine revs,will if done often over stress the engine, if you red line a cold engine you run the chance of piston & bearing damage, as for the odor, check for any coolant leaks onto the exhaust.star there.
