2004 Mazda 6 rear rotor removal
2004 MAZDA 6
68,000 MILES • 4 CYL • 2WD • AUTOMATIC
PAULWILLIAMS003
after removing the rear calipar, calipar bracket and two screws holding on the rotar. How do you remove the rear rotors from this point.
I've tried hitting the rotar with a small 2 pound hammer with no luck.
Thanks
Paul
Jan 22, 2009 at 8:52 AM
DAVE H
  • 13,384 POSTS
A little lubrication and a bigger hammer !! REAR BRAKE ROTOR Removal & Installation Raise and support vehicle. Remove rear wheel assemblies. Remove components in the order indicated in the illustration. See Fig. 16 . Machine rotor if lateral runout exceeds specification. Replace rotor if measured thickness is less than specified minimum thickness. See DISC BRAKE SPECIFICATIONS . To install, reverse removal procedure. For disc pad installation see, REAR DISC BRAKE PADS . Tighten all fasteners to specification. See TORQUE SPECIFICATIONS . After installation, depress the pedal several times, rotate the wheel by hand, and verify that the, brake does not drag.
https://images.2carpros.com/forum/automotive_pictures/266999_brake_11.jpg
Jan 30, 2009 at 3:07 PM
