HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mazda
6
Engine
Air Filter
Replace/Remove
2004 Mazda 6 oil in air filter
KASTONE62
MEMBER
2004 MAZDA 6
6 CYL
FWD
AUTOMATIC
117,000 MILES
I had my oil changed and they found the air filter had oil on it. What would cause this?
Saturday, July 18th, 2009 AT 8:52 PM
MECHANIC
Hi there,
This is normally due to excessive crank case pressure, have a leak down test done to check ring condition and get the PCV valve changed, start here.
Mark (mhpautos)
SPONSORED LINKS
Saturday, July 18th, 2009 AT 9:04 PM
Please
login
or
register
to post a reply.
Related Air Filter Replace/Remove Content
2004 Mazda 6 Engine Swap
I'm Trying To Find A New Engine For My Mazda 6. I Was Wondering If A 3.0l V6 From A Mazda Mpv Would Fit In My Car. What Do You Think?
Asked by
Hils2493
2004
MAZDA 6
GUIDE
Air Filter Replacement
Changing the air filter for your car is easy to do and will save you money as well as help your engine last longer. This filter removes contamination from the air the engine...
Engine Oil Change And Filter
My Oil Light Has Come On So I Checked The Level And It's Over The Full Mark. I Want To Change The Oil Out Witht He Filter Can You Help?
Asked by
Coopz292
6 IMAGES
2009
MAZDA 6
Serpintine Belt Or Timing Belt
What Does My Car Have
Asked by
myboysdma
2003
MAZDA 6
Mazda 6 Timing Belt
2005 Mazda 6 2.3 Ltr Auto. I Accelerated And Herd A Thump, Tach Went To Zero. I Then Tried To Restart The Engine And Only Got The Whir Of...
Asked by
hawkertroy
1 ANSWER
2005
MAZDA 6
2005 Mazda 6 Computer Diagnostic Oxygen Sensor Issue
The Check Engine Light Came On And My Non-dealer Mechanic Said That P0132 - Ho2s11 Which I Guess Is An Oxygen Sensor Issue. My Mechanic...
Asked by
aliceiscool
1 ANSWER
2005
MAZDA 6
VIEW MORE
SPONSORED LINKS
Air Intake Boot Replacement
Fix an Engine with Low Power!
Low Engine Power
Online car repair manuals
