I am experiencing hesitation with my 2004 Mazda 6 V6 sportwagon EXACTLY like the person who posted their problem in 2008. I also was able to retrieve PO170 and PO 171 codes using an OBD reader from the local Autozone store. Supposedly, too lean on the left and right cylinder banks.
I have replaced the plugs, cleaned the MAF, and replaced the PCV valve and hose. The check engine light is out, but maybe because in will take a few miles to register new trouble code(s). Still hesitating the same or worse than before. I plan on changing the fuel filter (integral with the pump in the tank) or the coils next. At $65 each, I'd like to be certain before replacing them. Any advise or past history would be appreciated.
Here is the header for the posted problem in 2008.
Posted at Mon Dec 01, 2008 6:28 pm
By cozmotone, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
2004 Mazda 6 6 cyl Automatic 48k miles
Jan 10, 2010 at 1:38 PM
