2003 Mazda 6 Squeaking
2003 MAZDA 6
88,000 MILES • 6 CYL • FWD • AUTOMATIC
BCOVIC85
  • 6 POSTS
when I pass people on the highway and i have to jump on the accelerator, every once in a while the transmission will squeak (like a squeaking belt) when it shifts i.e. cruising in 4th and then get on accelerator and upshifts to 3rd and when shifting back into 4th is when it squeaks (gears may not be exact cause its an auto- just for explanation sake). Is this someting serious?
Sep 13, 2009 at 8:13 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
There is nothing that comes to mind in the transmission that may be causing this noise, so i would ask you to first make sure that all the drive belts are in good condition and the tensions are ok, if all is ok with the drive belts, re post and i will look into this a bit further.
mark (mhpautos)
Sep 16, 2009 at 7:09 PM
