2003 Mazda 6 Rough Running
135,000 MILES • 4 CYL • FWD • AUTOMATIC
ROBERTSONSTUDIOS
Sunday morning it started running very rough. It stopped after about 30 seconds. It ran fine the rest of the day (135 miles of driving). This afternoon it came back and didn't stop.
It was a little low on oil so I topped it off, but that didn't change anything. I drove it down the street and back and noticed that the CEL was flashing slowly 16 times then staying on solid. Does anyone know what that means? Or if there is a way to get a more specific code to flash?
Aug 3, 2009 at 5:17 PM
DRMGUI
I recently had a similar issue with my Mazda. Mine is a V6, but the issue was due to a bad coil. Not sure if it's the same w/ a 4 cyl, but the 6 cyl versions have an individual coil for each cylinder. It didn't quit completely, but was firing intermittently, which made it run rough. Pretty expensive fix on the 6 cyl because they are hard to get to so there is a lot of labor. Then you have to decide to just change the bad one, or change them all while they are in there.
But the issue will surely come up during a diagnostic.
Aug 18, 2009 at 2:55 AM
CULPGRL4
mine too is doing the same thing i have replaced 3 coil packs now i would recommend if you could change them all at once do it it is very difficult to keep tearing the car apart to change them because after u fix the one that is bad it seems a couple weeks later another one goes bad
Nov 15, 2009 at 6:10 PM
