2003 Mazda 6 Codes po171 and po174
2003 MAZDA 6
105,000 MILES • 6 CYL • FWD • AUTOMATIC
EPADGETT
These codes read banks 1 and 2 to lean the car seems to be running fine, except for maybe alittle rpm bouncing when idling, I cleaned out the MAF sensor myself not much of a change, I also sprayed carb cleaner to check for leaks, anyone have other ideas
Jun 13, 2009 at 10:03 AM
A lean fuel condition can be caused by:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
Jun 13, 2009 at 10:08 AM
EPADGETT
could it be a clogged fuel filter
and how much does each of those cost to repair
fuel pump prob. 300
MAF sensor 90
but what about the others
thanks
Jun 13, 2009 at 10:18 AM
You need to check every one of them out.
Jun 14, 2009 at 8:41 AM
EPADGETT
well I cleaned the MAF sensor my self not much of a change
checked for leaks with carb cleaner didnt find anything
there seems to be no significant loss in power
and i may be idling slightly rougher then it use to
can you help me narrow it down from there
Jun 14, 2009 at 10:01 AM
JGHENDRICKS024
i am experiencing the same issue with my 2003 mazda and curious if you ever find the root cause of eng code 171 & 174?
thanks
Aug 30, 2010 at 12:43 AM
