2003 Mazda 6 CODE 1410 and transmission
86,000 MILES • 6 CYL • FWD • AUTOMATIC
BCOVIC85
  • 6 POSTS
A few weeks ago my check engine light came on so I pulled the code in my Mazda and it was a P1410. I wasn't quite sure what that was so i did some research online and found out that it was a EGR Boost Solenoid Valve or a VAD solenoid malfuntion. I was wondering if that is or could be related to the transmission because yesterday my AT (automatic transaxle) light and my traction control light came on and the car would not make it out of my driveway. So is this a tranny problem (1410) or something else and now my transmission is bad?
thanks
May 23, 2009 at 3:37 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Code not related to trans. Need to have codes read for trans. Post will advise
Thanks for donate
May 23, 2009 at 5:17 AM
MUNI0MULA
My car is having the same issue...did you ever find out what it was?
Jul 22, 2009 at 3:06 AM
DOCFIXIT
  • 18,828 POSTS
Don't know never heard back. Have you checked for trans codes? you have a P1410?
Jul 22, 2009 at 7:56 AM
MUNI0MULA
The codes that were pulled from my car were p0712 and p2101...
Jul 22, 2009 at 8:58 AM
DOCFIXIT
  • 18,828 POSTS
p0712 is trans fluid temp sensor short or open
P2101 Throttle Position Sensor out of range
TPS most likely to cause your problem.
Jul 22, 2009 at 9:06 AM
MUNI0MULA
What is the TPS? Sorry...I am clueless.
Jul 22, 2009 at 9:45 AM
DOCFIXIT
  • 18,828 POSTS
Sorry Throttle Position Sensor on throttle body small box with wire connector on opposite side where throttle cable attaches.
Jul 26, 2009 at 5:35 AM
