2009 Mazda 5 accessory socket
8,850 MILES • 4 CYL • FWD • AUTOMATIC
BURKETHOM
How does one replace the accessory socket (aka cigar(ette) lighter socket)? The fuse is good. No juice gets to the socket, though the one in the rear of the car works fine.
Sep 20, 2010 at 5:01 AM
LAMBART
There is a second fuse box on the right side of the dash. You have to open the passenger door to see it. The fuse you want id labeled CIGAR. Be sure to use the right size fuse as indicated on the back of the fuse box cover-probably 15A.
May 5, 2012 at 12:55 PM
